New to Freelander
Home › Forums › General › New to Freelander
Viewing 3 posts - 1 through 3 (of 3 total)
  • Author
    Posts
  • #4255
    Paul Briggs
    Member
    Hi Im new to the world of freelanders and looking forward to interaction in this group
    #4296
    Hi I am also new to Freelander and looking forward to sharing info and getting tips on updating and events and meeting. Hopefully with help from you guys. Regards NEW OWNER Phil
    #4303
    Kevin Burrow
    Member
    Hi Paul and Phillip
    Hope your Freelander experience is going well. I bought a 2007 Freelander 2 td4 SE last October . It has done a total of 170000 miles.
    It is in very good condition inside and out .
    Problems so far was the reduced performance warning coming on. Looked at forums for advice on this and found it was the turbo hose that had split. Replaced that and was ok for a while but then started to get the same warning. Changed the fuel filter and has been fine since. After 25 years or so of company cars, it has been quite good to get the socket set out again. Also changed the auxiliary belt tensioner as that was making a knocking sound on tick over.
  • You must be logged in to reply to this topic.
